Hello,
I have just replaced my rubber selector shaft coupling that connects between the box and selector rod with a new solid billet piece. I now have a rattle that sounds as though the selector rod is knocking against something in the tunnel..
I have removed the gear stick and from what I can see there
is a brass bush through an eyelet type bracket that holds the rod up towards the stick but nothing else down there.
I've moved the selector rod up and down, side to side and there doesn't feel like there is any horizontal or vertical movement.
The rattle occurs while i'm driving, if i hold the stick with a little bit of pressure it goes away.
The rattle isn't there in neutral. It did make a slight rattle before I changed the coupling at the back, but the solid coupling seems to have magnified the sound.
It changes gears fine apart form 3rd to 2nd but I believe this to be the second gear syncro..
Any help would be appreciated.
Regards,
Conan
x275 ·
