Anyone know where I can get new field coils for a Bosch 68 beetle generator?
Or is there any "local" auto electrician that does refurbishment?
Priit 0433 882 445 North Parramatta 2151
viiking ·
https://forums.aussieveedubbers.com/threads/101977/wtb-field-coils-for-12v-beetle-generator-sydney
viiking ·
BUGBOY ·
viiking ·
Yes I know about the coils. I thought I could do this myself. Cleaned it all up including armature, new bearings, re-wrapped the coils in cotton tape BUT I could not compress the coils back in the generator enough to allow clearance for the armature. I guess the coils shape is now incorrect and I cannot get them to fit properly. 😠vw54 wrote:the field coils usually don't break down unless a wire is broken or cut you can test with a multi meter
they just need cleaning and applying some insulating material like a thick lacquer
Why don't you just buy a fully reconditioned Genny from a VW place ??? lost less work
robb ·
viiking ·
Thanks for all the replies. I also tried the self amalgamting tape from Jaycar FIRST but found that it worked so well keeping in the shape that I couldn't get it to pull down properly. I then used cotton tape (bias binding) as was recommended on some old car restoration sites, but also couldn't pull it down enough.robb wrote:your almost there use the inner of the coil to get your shape back I painted mine with shellac from bunnings let it go 3/4 off then wack it in and tighten it up and that was longer than I care to remember ive done a few oihers since just remember to wire the coils up the same way or it wont work lines of force and all that and some of that heat proof insulation jcar electronics cheap small pack all colours good luck
AA003 ·
vduboy ·
viiking ·
I would only be able to accept if you throw in the engine, transmission, wheels and tyres and the baja body.😂vduboy wrote:I might have a unknown condition genny left over from my alternator conversion mate, if its still there you can have it when you pick up the body.
vduboy ·
vduboy ·
