Parts F/S QLD - more added
https://forums.aussieveedubbers.com/threads/101981/parts-fs-qld-more-added
1916baja ·
Hi guys, i cleaned out my garage today and i have a few bits i'd like to get rid of...
Bay kombi towbar - $50. Sold
1970 bug standard Fuel tank with filler neck -$40 sold
Tail light housings -$20 I think they might be for 50/50's but i am unsure.... they came with our buggy years ago and it had 50/50's on it. Sold
Pair of mazda 6 seats -$150 - offers?? We bought these from kuston kombi a couple of years ago to put in our kombi but never got around to it... they are one of a few modern seats that are low enough to bolt straight in and fit under the steering wheel of a kombi. They are presentable and you could just bolt them in and use them or get them recovered, i can help with recovery if required.
Mick
Mt gravatt east 4122
0439002870
or contact on here
1916baja ·
LUFTMEISTER ·
text sent = re: taillight housings cheers
Sides ·
PM sent re tank Mick.
1916baja ·
Tail light housings sold pending pick up.
1916baja ·
Fuel tank sold pending pickup.
1916baja ·
I found some more stuff...
Brand new Empi cal look window rubber kit 65-71 - $50
1970 standard bug bonnet ( ratty with oldskool pinstriping) -$50
1970 standard bug front guards (little rusty and dinged up) -$10 each
1970 standard bug decklid - $15
Wide 5 splitty wheel - $30. Sold
Brand new Bay window inner window scrapers - $20 sold
Oil bath air cleaner -$10
1500 cooling fan -$5
2 x smiths amp and volts gauges and 1 x unknown mech oil pressure gauge, all chrome surrounds would clean up good - $10 each. Sold
Brand new stainless eyelids bay window kombi / beetle - $20. Sold
Brand new Golf fuel gauge sender -$20. Sold
Gt 40 coil - $10
Genuine USA made Facet low pressure electric fuel pump -$30. Sold
1916baja ·
1916baja ·
1916baja ·
LIFE IN THE LOW LANE ·
I'll grab the bay window inner scrapers Mick. Bring em to dubs by the abbey and ill fix you up then.
cheers Brennden
1916baja ·
All yours mate, see ya then.
Scrapers sold.
hus22l ·
Pm sent on the gauges.
1916baja ·
No pm received.
1916baja ·
Gauges sold pending payment
1916baja ·
Tow bar and eyelids sold pending pick up....
Riot Starter ·
Hey,
Regarding the fuel pump. Can it just be plumbed in as pictured, then remove the mechanical pump, and away you go?
Or do you need to run a pressure reg also?
And lastly, are you willing to post?
Regards
Ben
1916baja ·
Yes it can be plumbed I as pictured, it depends on what carbs you are running I guess... It's a low pressure pump set 1-4.5 psi I think. You really should run a reg to get consistent fuel pressure but I never did... I had it on my 1916 race motor with dual 44 idf webers. It worked fine. Yeah I don't mind throwing it in the post.
Riot Starter ·
Ok cool, i'll take it 🙂
PM sent
Ben
1916baja wrote:Yes it can be plumbed I as pictured, it depends on what carbs you are running I guess... It's a low pressure pump set 1-4.5 psi I think. You really should run a reg to get consistent fuel pressure but I never did... I had it on my 1916 race motor with dual 44 idf webers. It worked fine. Yeah I don't mind throwing it in the post.
VWMA Editor ·
Me take fuel gauge sender for golf. See you at abbey.
Craig
1916baja ·
Righto Craig. All yours.
1916baja ·
Fuel pump sold pending payment
Golf fuel sender sold pending payment.
1916baja ·
Bump... Can bring stuff to the abbey!
1916baja ·
Bump. Offers on anything??
1916baja ·
Bump
PHAT BUG ·
That's not a Splitty rim, It's early Type 3.
Is it still available?
1916baja ·
Sorry mate, it's gone.... The new owner pointed that out to me when he picked it up.
