Hello,
Just wanted to find out the cheapest way to convert a '64
beetle to disc brake front end.
All advice much appreciated.
Conan
x275 ·
https://forums.aussieveedubbers.com/threads/102023/converting-64-beetle-to-discs
x275 ·
vwo60 ·
x275 ·
sander288 ·
x275 ·
vwo60 ·
x275 ·
psimitar ·
But the rotor is not seperate from the hub so much more expensive for future maintenance costs.1303Steve wrote:Hi
The system that Vintage Vee Dub sells is pretty good, its not Chinese junk like other people sell.
PS I beat Birchall
psimitar ·
$120/hr is the average but you have to pay some their travel time too at the same rate.x275 wrote:Does anyone know roughly how much the compliance will cost ?
hrastovica ·
psimitar ·
Depends on Vic transports modification rulings but every state says that wheel adapters/spacers are illegal and so apart from Vintages design all others use a plate to allow the fitting of the wide 5 wheels. This means it's down to an engineer to agree the plate is a permenantly mounted part of the disc conversion and sign off on the modification.hrastovica wrote:Regarding compliancing, do we have to do the same in Victoria?
x275 ·
Reason I was asking was the car I was looking at for my partner has front drum brakes. I had never driven an all drum brake car so I had just assumed it would pull up like a tug boat..psimitar wrote:But the rotor is not seperate from the hub so much more expensive for future maintenance costs.1303Steve wrote:Hi
PS I beat Birchall
As for the OP. Why do you wish to go disc brakes? Do you have a hi-power engine or wish to drive the vehicle hard on twisty roads or track days?
Reason I ask is that a well maintained Drum system is perfectly adequate to haul a Beetle to a standstill.
Are you having a lack of performance from the vehicle or are you more used to driving a modern everyday car compared to the Beetle? A lot of people find Beetle brakes not as responsive as a modern car and hence why they think it needs upgrading.
Just a few questions to ask yourself as could end up saving you a wad of cash cos wide 5 disc brake kits are far more expensive than having to update a later 4 stud Beetle plus you have to show the engineer you wish to use for the blue plate the kit you wish to buy as if they don't like it they won't ever sign off on it 🙂
psimitar ·
Cool. Glad you found the brakes to be good.x275 wrote:Reason I was asking was the car I was looking at for my partner has front drum brakes. I had never driven an all drum brake car so I had just assumed it would pull up like a tug boat..
But I was wrong it pulled up ok.. So I don't think I would need to do the conversion.
