a good vw replacement engine
https://forums.aussieveedubbers.com/threads/102025/a-good-vw-replacement-engine
vwo60 ·
http://www.pompolodesign.com/pompolo-design-works.html
vwo60 ·
Internals
vlad01 ·
hang on? what this engine?
911 engine with 2 cylinders chopped off?
wow wtf!
68BUS ·
And what is with the chain?
Does that live inside the engine all the time or is a build thing?
kombibob ·
Wtf! Very cool
68BUS wrote:And what is with the chain?
Drive chain for the over head cams.
And look at all those main bearings. Awesome, looks like they have cast thier own block and crank and the rest is Porsche....very nice, 175 hp too......😍
sander288 ·
http://www.capricorngroup.net/fileadmin/files/images/capricorn_Anzeige_Motorsport_UK.pdf
^^^ something else if you've got the dosh! 👍👍👍👍
ragged ·
🥲Some engines are designed right from the beginning with performance as a priority. (see pic above)
Some are designed to cost as little $$$ to produce. (Look in your driveway)
The thing they have in common are they are able to be driven flat out all day and get you home.
The saying, "can't make a silk purse out of a pigs ear" is beginning to make perfect sense!
Dave
Subarugears ·
Wow, I had a look at their 718 5 speed gearbox. $40,000 Euro plus VAT, packing and shipping!!!!!!
vlad01 ·
that drive the cams on the head. the shaft to which they are connected to is not a cam but the IMS. That thing with the green o rings is a 2 stage dry pump by the looks of it.
vlad01 ·
I like the locating pins in the main saddles.
vwo60 ·
Only $30.000 for the basic engine, up to 2.8Ltr can be built, ready to turbo.
vlad01 ·
sounds bout right, thats what an engine like that would go for.
68BUS ·
Thanks for the answers on the chains fella's.
sander288 wrote:http://www.capricorngroup.net/fileadmin/files/images/capricorn_Anzeige_Motorsport_UK.pdf
$156k for the motor.........faaark !
http://www.capricorngroup.net/fileadmin/files/documents/Artikel/Preisliste_cc587_2LC4_20120601_15_01_2013.pdf
vlad01 ·
I was like what kind of engine cost that much?
then I looked, Carrera quad cam, of course. They cost a min of 100k for a rebuild original. So yeah thats not so ridiculous given what they go for.
but still, deep pocket people only.
pete wood ·
I remember reading somewhere about plug changes on these motors. Apparently you needed an "asbestos octopus" or you just pulled the whole motor out.... 🤪
I'll be keeping my stocker for now I reckon. 😉
So how do you set your valves on one of them motors??
vwo60 ·
Plugs would take ten minute's and are visable in the view of the engine in the car, the valve adjustment is the same as a 911 with adjusting screws using a 13 mm spanner and a special feeler gauge.
bajachris88 ·
vlad01 wrote:I was like what kind of engine cost that much?
You certainly wouldn't buy it for the HP! $ per HP could go a VERY long way at half that budget. Just saw they wanted $19,000 for a crankshaft! and $2200 for a distributor... wow!
Parts wise, must be the worlds best paid fitters and turners.
vwo60 ·
Nothing to do with highly paid fitters and turners, limited production, exclusivity and quite a few people who would not think twice about it.
