My new motor for my street buggy is almost there, so far.
Beautifully put together by Anthony Lees AREOPLATE Perth
2084cc
Bubble top case with oil squirter to underside of piston
78.4 Okrasa crank, dowels drilled deeper
Scat super race 5.5 rods
ARP 2000 bolts
Mahle 92mm pistons, thick wall bores , coated skirts and crown
w120 cam
1.25 Berg rockers
28mm ultra light lifters
Scat moly file down push rods
CB 044 Ultra mag plus heads 42x37.5
Berg 26mm oil pump , plugged for full flow
sand seal pulley
Compression 7.9 to 1
Balanced by HARRIS ENGINES Perth
Yet to come
Distributor maybe CB Magnaspark or Mallory with 6al
t3/4
600 Holley vac
Pipe work From Ron Lumus
Slowly getting there, only taken 2 years so far 馃檪
grogy 路
hi , i had that crank in a similar motor, a bit more hypo tho. the dowels in the crank are smaller than most similar cranks and mine twisted out in a short time. i had it drilled for wider deeper dowells and it was fine from then on. were u recommended to drill the dowels before u started
turboboy 路
Howdy
Yes Berg recomended it , they are only deeper ( longer) not wider
It all so has Raceware studs and Berg straight cut gears
grogy 路
very nice, is it goin in a fiberglass buggy
ian.mezz 路
we have a similar motor in our car.
there is going to be a lot of Holley Turbo bugs on the track soon.
Here is ours
1916baja 路
I hope so! My new combo is pretty similar but with a turbo grind 120, scat flanged crank, 94mm bore,same heads bigger valves, bigger turbo, bigger holley and more comp! Although it is strictly a race motor! Should be a ripper motor for a buggy! Talk about loose!
hellbugged 路
Looking good
... Don't look like berg rockers tho
turboboy 路
Yep glass body , Taipan
Your right with the rockers, well spotted . Yes they are EMPI's ,my mistake sorry 馃槉
Nice build should be fun in a light buggy, 1.25:1 with W120 is ok, just run it.
turboboy 路
Dave Kawell said it's close to a FK 45 which he uses on some motors , that with the 1.25's with the 120.
So that's where I got the combo
So that's cool we'll see how it goes
So many choices, so many combo's
fish26 路
Dave Kawell also had input towards us using FK43 with either 1.25 or 1.4 in the turbo motor.
humpty 路
I'm looking forward to having a race against you next season Richard.... Given your weight advantage, it might be a fun chase!
dragvw2180 路
JMHO , If I am going to buy a cam for my engine and a set of rockers I would rather buy one ground for the ratio I am going to run. Will your combination work , absolutely but I worry about excessive strain/ wear on the componants. I have done it in the past when I already had the engine assembled and wanted to try just a little more lift . Dave Kawell is someone I believe in , has given me nothing but excellent advice. Your engine looks great and I bet will be alot of fun, Mike McCarthy
turboboy 路
Have had some more bits arrive. Thanks Rod P
See pic.
Talked to Lummus on Thursday, he has started but going slow. Have changed a couple of things.
Intake plenum is now an upside down D shape ( flat on bottom) the reason is to help fuel stay in suspension just like the tee on the in take manifold.
The carbie is now an alloy body Holley Street Avenger 670cfm not the 600 we originally planed to use.
will have to wait until it's all here to work out throtle pedal,cable etc
humpty 路
Loving the toys.... That FPR looks very familiar... Looking forward to seeing the plumbing from Ron.
turboboy 路
Received some pic's from Ron Lummas of the turbo system been built.
Will have some more pic's tomorrow hopefully
Oh so close
turboboy 路
new build
turboboy 路
new build
turboboy 路
new build
turboboy 路
new build
turboboy 路
new build
humpty 路
Nice..... Hows the car coming?
turboboy 路
Car is still rego'd
Have to put new disc's and drums on and pads. 5x130
Shim the front end
Have to work out throtle cable when motor is in.
Oil lines
a bit of wiring
the box will come soon, just want to get it going, so no beating up on it for a little bit.
turboboy 路
Some more pic's,馃槑
turboboy 路
more pic's
turboboy 路
some more pic's
turboboy 路
more pic's
turboboy 路
Another pic came in from Ron Lummus racing Facebook page
turboboy 路
getting closer
turboboy 路
closer
turboboy 路
closer
humpty 路
Nice. Rich.... Any idea when it will turn up?
turboboy 路
Still some work left on intake and manifold brackets then off to plates and polisher's.
So maybe a month.
turboboy 路
closer again
turboboy 路
All most there, parts should start arriving soon.
humpty 路
The build has been getting a little traffic on Ron's FB page to Rich!
turboboy 路
Carbie arrived just before Xmas.
670 vac sec.
:tu
essex 路
Great work!
turboboy 路
Some nice shiny bit under way soon.馃槑
Such nice looking work
No muffler pipe in pic's yet , just the unmuffled tail pipe
fish26 路
Nice, I bet you can't wait......
modnrod 路
turboboy wrote:Such nice looking work
Comp Industrial Coat or Ultra Chrome?
turboboy 路
Yes cant wait.
It's been a long wait.
Coating is ceramic on steel and polish on alloy , done in USA.
Still yet to work out fuel tank and oil lines for cooler etc
modnrod 路
turboboy wrote:My new motor for my street buggy is almost there, so far.
2084cc
I keep forgetting to ask if you have a contact number, if he does machining work too?
Does Harris still do the work do you know?
turboboy 路
Yes Harris engines dose machining.
They can do all most anything.
Rebores, head work, alloy welding etc., but he doesn鈥檛 have a line borer for VW
check their web site http://www.harrisengines.com.au/
Ask for Mark tell him Richard put you on to him
Nice chap very helpful and always has VW/356 heads in there.
But Ron is retired
modnrod 路
turboboy wrote:But Ron is retired
馃檨 So is Graham (Southsides).
But thanks for that though, I'll wander on down and see Mark next time I'm in Perth.
Cool! 馃槑
Regards,
Dave
humpty 路
Looking good there Rich.... When will the stuff arrive?
turboboy 路
Howdy
hopefully in a week, but things take time,as you know
turboboy 路
Some more bit's arrived today, 8 days shipping time from California, was hoping for more bits.
But the wait will be worth it.
turboboy 路
some more bits arrived
More arrived today,Post when slow when it hit Australia, 8 days to get here after arriving in Aus.
Slowly coming together馃槑
LOWBUG 路
How much power do you think this beast is going to make, and in a buggy, hold the hell on.
turboboy 路
Maybe 200 to 250hp , which is what I'm shooting for.
Lummus recon's around 300, I would say he is talking flywheel hp
matberry 路
Schweeeeet
turboboy 路
some more shinny bits arrived
turboboy 路
turbo arrived the other day.
Just intake and muffled exhaust to come
turboboy 路
coated exhaust and polished intake
turboboy 路
Intake and buggy
turboboy 路
Intake and buggy
turboboy 路
intake manifold
turboboy 路
Last bits arrived.
Now to put it altogether
sorry about poor quality pic
turboboy 路
Some shinny bit's bolted to my motor (thanks Anthony)
slow going from me due to back/ankle surgery
Any how looking pretty
Doug Sweetman 路
Wow nice indeed
dragvw2180 路
Absolute beautiful work, you have every right to be proud that engine and I would bet Ron was close on his estimate of HP . I especially like the muffler and pipe setup . Mike McCarthy
