Aussieveedubbers 路 Bugs
Stinger exaust ??
https://forums.aussieveedubbers.com/threads/102278/stinger-exaust
Kent 路
Hi all.
so im interested in fitting a stinger exaust in my standered 71 Super.
but am unsure as to any changed need to made or they just fit in? and do i neeed to replace anything ? if anyone ciould show me some photos of exausts that would be good. my mind is not 100% set on a stinger, but im after something loud 馃槀馃お
(i have some typical P Plate driver quailtys) 馃
Kent 路
heres the website ive found that has a alot of options !
http://www2.cip1.com/ProductDetails.asp?ProductCode=C12-2009-13
lohoon 路
You have to have extractors fitted. They bolt right on. Go for it!
sander288 路
depends on what size motor you are running and carbs etc..... but having a stinger will be illegal on the street
Kent 路
spewwing that there illegal, do you know why ?
sander288 路
All cars must be fitted with an effective muffling device, noise cannot exceed 95dB, and the stinger presents a hazard for cars and pedestrians
Kent 路
anyone have idea if there are legal or not ? considering this instead of a stinger.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-D-2564-13
waveman1500 路
The stingers stick out a long way and they are hot enough to burn people. That alone makes them illegal for safety reasons. They also don't do much muffling, so your car will be too loud. Those twin tubes you linked to also look like they will be too loud to be road legal in Australia. You need something with actual mufflers in it, like a "quiet pack" exhaust, or a hide-away.
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-6066
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC-C10-6068
In terms of buying from the US, I've previously had good service from VW Parts Unlimited (now Pierside Parts) and they had the cheapest shipping at the time. USPS is usually a lot cheaper than FedEx.
I have a sidewinder on mine, it's a nice exhaust and fairly loud. Mine is a bit big for a standard engine though, I think the sidewinders are more designed for big bore engines.
Aussie Dubbin 路
Just buy the empi merged headers(not the ones pictured above), and a phat boy mufler. Then the stinger you could buy for 80 odd dollars. Buy from George at classics will be cheap. BUT, you will loose your heaters.
A better option would be an A1 sidewinder including mufler with 10mm flanges from Vollks.com.au they used to sell it for $300 bucks on special, do your research, you shouldn't be spending more than $400 bucks. Good luck
Aussie Dubbin 路
https://www.classicveedub.com.au/cvd_new/part_detail.aspx?parts_id=7398
http://www.vollks.com.au/store/Sidewinder-Performance-Exhaust-System.html
I would go the sidewinder it should give you the note you are looking for
waveman1500 路
Aussie Dubbin wrote:Just buy the empi merged headers(not the ones pictured above), and a phat boy mufler. Then the stinger you could buy for 80 odd dollars. Buy from George at classics will be cheap. BUT, you will loose your heaters.
I paid $550 for my sidewinder at the Adelaide Day of the VW 2 years ago and it doesn't even seal to the head flanges! Oh well...
On a daily driver I would really recommend keeping the heater boxes. They are technically a legal requirement for demisting purposes, and they are worth having if you take it out on a cold winter's morning.
snitz 路
Vehicle standards SA states window demisters are required on cars built after 1971 and windscreen washers after 1972..FYI.
SuperOwen 路
Those ones on the volks website aren't A1 sidewinders, just copy versions.
Bizarre 路
Doesnt Rod Penrose do a range of A1 ??
snitz 路
Sure does..need to find his link on here that showed pics etc of them as I dont think they are all displayed on his website yet.They might be up on his site now though.
