Aussieveedubbers 路 Buying, Selling & Swapping Parts
[FS - QLD] NOS 85.5 pistons $50, P&B kit $150, Garret turbo with bits $150
https://forums.aussieveedubbers.com/threads/102299/fs-qld-nos-855-pistons-50-pb-kit-150-garret-turbo-with-bits-150
bajachris88 路
G'day,
Just clearing some excess shed stock. The following items are for sale. Will take money or services (IE: bottom end dynamic balancing, machining my stripped heads open to 94mm, fitting steel threaded inserts for my spark plug holes, any new kennedy 1700lb/2100lb pressure plate kits, exhaust and muffler welding/ making for the baja, engine assembly)
1. SOLD!! AS41 magnesium case, 1600 dual relief, line bored by Leons back in the day, ready to be reassembled. (1mm oversized on bearings, and 1mm machined on thrust - Thanks Sides and DB 馃檪 )Been in storage in my office. Blotching is from residue of the acid dip clean up. PRICE: SOLD.
2. NOS brazilian 85.5 pistons, with gudgeon pins and retainers. No rings or barrels. PRICE: $80 (now $50)
3. New piston and barrel kit, complete with gudgeon pins, retainers and rings. $180 (reduced!! $170). Classic vee dub is $210 and CIP1 is $255 delivered to my door. save $40 at the least! (NOW $150)
4. $250 (Now $150) MGT22S Genuine Garret (by honeywell) turbocharger + flanges + wastegates. From a bmw x6m 4.4 litre v8 twin turbo (so it would be safe to assume its good for 2 litre or so per turbo. You could put on smaller capacity motors but would boost at a higher rpm when the exhaust air flow picks up. )
x6m's started in 2009, so it wouldn't have many km's at all, in working condition. Has journal bearings but x6m turbo car reviews brag of these turbos given the light weight impellors reduce the lag time significantly, feel free to google. Has water cooling ports available, otherwise leave them disconnected and run a turbo timer to prevent turbo oil coking.
I paid $150 or so for the flanges to be laser cut. However, they need to be lathed/machined to meet the V-band flanges on the turbo housing, and fit inside some generic v-bend clamps for connection.
I have the original waste gate and an after market one that fits the wastegate mount. The original wastegate is normally open with a vacuum pump keeping it closed, thus to keep things simple a 'normal' normally closed wastegate was purchased, where opening is activated via 8psi think it was boost pressure (adjustable with boost constroller). The threaded rod does need to be extended a couple cm's.
This would make a beaut bit of kit with mod-con performance with a little work (lathe and time).
PRICE: $250
pics:
Engine case:
2. NOS Pistons 85.5mm
3. New Piston & Barrel kit 85.5mm
4. Garret MGT22S turbo
[imghttp://i126.photobucket.com/albums/p86/bajachris88/IMG_0560_zpsa3216294.jpg[/img]
Seller: Chris Leete
Contact: Prefer via PM or mynameischris88@hotmail.com.
phone: 0402 568 003
Thanks for looking. 馃檪
bajachris88 路
Bump. Sides and DB inform that the bearings are 1mm oversize and 1mm machined on thrust for AS41 case. Thanks guys 馃憤
bajachris88 路
Bump.
Make me an offer.
Will consider swaps/part trades. or tools...
buff back and respray my red faded roof in monza red acrylic paint which i can supply... down the pillars to halfway up the door (excludes bonnet, nose, guards, rear cowl etc of baja, the paints not too bad there).
miniman's buggy looks tempting too as a swap 馃檪
Would Warwick coming up entice anyone to pick up the turbo 馃榾!?
or take the lot for $500...
bajachris88 路
Case is now sold!
rest still available.
bajachris88 路
If it motivates,
all proceeds go the the "Chris's head flycutting to 94mm with valve seat job and steel spark plug inserts installed" foundation.
bajachris88 路
Bump
bajachris88 路
bump
matberry 路
Chris, I'll take the 1600 PB kit and pistons if still available. Are you going to W'bank on saturday?
bajachris88 路
No problem's Mat, yup still available.
Nah got a xmas in July shin-dig with the fam from 12pm onwards on Saturday, but your more than welcome to drop around either Sat morning, or evening. We'll be at Rocklea early saturday morning for the Brissy markets if thats west enough to not be too far from Willobank for you for convenience etc. Its usually a pretty early start at the markets.
matberry 路
Thanks mate. PM sent
bajachris88 路
Pistons and P&B Kit & Turbo still up for grabs! 馃憤
TheMiniMan 路
sorry Chris,,, cant swap the buggy for your bits, :-) sorry :-)
but i am keen on the hairdrier if it`s still up for grabbys
can we hook up somewhere for gork & chat about possible purchase of said huffer?
Matt
0407 135 656
dave1342 路
Interested in the b&p, will they fit a stock late type 3 engine. I'm in Brissy and can collect
bajachris88 路
TheMiniMan wrote:sorry Chris,,, cant swap the buggy for your bits, :-) sorry :-)
Matt
0407 135 656
G'day Matt 馃檪, hairdrier is still available. Is Saturday Afternoon ok?
bajachris88 路
dave1342 wrote:Interested in the b&p, will they fit a stock late type 3 engine. I'm in Brissy and can collect
Yes they will suit 馃檪. The late type 3's are 1600cc, and thus use the 85.5mm p&b kit, which will also suit type 1 and type 2 1600cc engines as they are the same long block. Pretty nifty hey! I'm free Saturday afternoon if you'd like to inspect.
dave1342 路
Yeah cool. Can come over sooner I'm only in Carina. I will defo have them off ya
bajachris88 路
dave1342 wrote:Yeah cool. Can come over sooner I'm only in Carina. I will defo have them off ya
Awesome Dave, well i will be home tomorrow evening after work if you're free. Say 6pm? If so i'll PM you an address.
dave1342 路
Just realised I'm on baby sitting duties this week sorry ( wife just reminded me) will have to be Saturday you free in the morning ?
bajachris88 路
After 10.30am 馃檪 馃憤 Is that ok?
You have PM
dave1342 路
Perfect will call Saturday morning
