vwo60 wrote:Just pack your standard bearings with high temperature wheel bearing grease that is compatable with your gear box oil, works in the front wheel bearings.
Hi Dan,
Front wheels don't have any oil??
plus there are two roller bearings in the front wheel hubs..
not a ball bearing.. and the oil would dilute the grease eventually... if using grease make sure its Lithium based MOLY grease... MUST Use this grease..
chassis grease is crap.. clay based usually...
I haven't read of anyone on here complaining of wheel bearings
wearing out prematurely because of low oil or no lubrication..
I would just leave it to the oil to lubricate the bearing..
just make sure the gearbox is full of Hypoid oil...
also a MUST USE oil...
make sure the bearing is a C3 and leaving one end sealed is a good idea..
