I don't think they are available new..
but there should be many of the parts available from people who have pulled a 68> beetle apart..
unless they were labelled unimportant and were trashed..
as were many little things that don't normally wear out.. lol
there would have been a lot of these gone into the trash with rusted out chassis....
Not sure about what number two is..??
I know there are valves/flaps both sides which turn the HOT air on in the back... [used them tonight].. lol
when You PULL the heater lever UP - You turn the HOT air ON.. which comes in the front floor and windscreen..
PULL the other lever UP which opens the two rear seat flaps/valves.. which fill the car with HOT air..
[is that what You need? one of those??]
BUT unless the HEATER is turned ON first... NO HOT AIR comes out the rear outlets...?? I always pull both Levers UP..!
they are just connected to the heater channels, so when the heater is turned off, no hot air from the heater boxes..
This is with a 1968>> ON Beetle... with two levers...
vinsueball wrote:Hi Folks,
Just wondering if anyone can help me out with:
- A set of Bakerlite heater connector tubes that comes through under the rear seats
- 2 - The valve that sits inside the left hand rear heater junction piece that directs heat down the main passenger side sub-frame
The first item has been damaged in the resto but can perhaps be repaired with fibreglass. The second item (the valve) is missing totally and if I can't get a replacement I'll have heated air constantly pumping into the cabin.
Can anybody help with these parts or tell me where I may be able to locate them ?
I'm located in the northern Brisbane suburbs.
