Been looking for a product like Picklex 20 for a while (just google it and watch the vids. Looks impressive) but there's no AU distribuon.
Then I realized I might already have something similar.
Rust Blast from KBS does something very similar and I already have the stuff cause I just used it on my chassis underside as a three step paint process. You see I'm just a hobbyist so there's often breaks in between finishing jobs so bare metal might not be able to be painted up immediately.
Spoke with Vaughan at KBS and found out as long as the job is stored dry KBS treated bare metal should last a long time possibly over a year or even more with no flash rust. Its also very easy to re-apply the Aquaklean and Rust Blast later just prior to paint if a lot of welding and dirt has hit the metal since the first Rust Blast treatment.
It can be powdercoated over or painted with normal car paint and you do not (should not) take off the rust inhibiting milky looking Zinc phosphate treated surface as you might expect. He recommended not wiping the surface with solvent or any other cleaner prior to paint. A dry tack cloth for dust then just paint directly on the clean, treated metal with your epoxy primer or even powdercoat if that's what your painting with.
I'm looking for any response on possible problems I might run into or compatibility issues anyone might see with doing this Zinc phosphate surface preparation under Epoxy primer and two pack paint process.
If there's no probs then I might be onto a winner combo for the backyard restorer.
eXraycer ·
