Fitted the Crane HI 6 ignition to No.8 Beetle. Starts and runs nicely, however when I tried to check the timing, there seems to be a problem.
With the timing light pointed at the pulley, in the usual way, and at around 3000 RPM, the timing 'dances' between about 20 and 40 degrees before TDC. It was set at 27, and I did not move the distributor. Maybe it's the 'multi-spark' ?
How do I correctly set the timing now? HELP!
HappyDaze ·
