I have assembled a new 74 mm x 94 mm engine here that is 100% brand new . All of the components have been inspected and assembled into a complete long block from the front pulley to the flywheel and from valve cover to valve cover . This engine has a comp. ratio of 8.2 and an identical engine was recently dyno tuned @ 109 HP . This engine will suit any type 1 , early type 2 or type 3 car . Here is a list of the components ;
Magnesium case
Forged 74mm crank
Forged lightened 8 dowelled flywheel
Forged I beam rods
Engle 110 cam
Engle lifters
CNC ported 40 x 35 mm heads
26 mm oil pump
Stainless pushrod tubes
Aluminium pushrods
Solid shimmed rockers
Billet sump plate
94 mm piston/barrel kit
Factory VW valve covers
This engine is priced @ $ 4930 and is located in Wollongong NSW and is available for pick-up or I can ship Aust. wide via Toll Express , ROD , 02-42729920 .
RodPenrose ·
