Camo wrote:Sure have. All mine are electronic and it's far easier than the old days.
Kev
Hi Kev
I thought that drilling etc those large holes in the beetle dash pieces was going to difficult, which it was, so I bought the two pieces with holes from the USA.. lol
and You wouldn't believe they are nowhere the same shape as RHD...
I thought if I reversed the plates they would still fit.. but NO..lol
Yes I fitted the Bright blue LEDs a while back.. but find the tacho one isn't lighting it up good enough at night due to where the bulb fits..
I replaced the metal VDO tacho with a plastic one but still the same.
so I've been thinking of drilling an extra hole or two to get it brighter.
[drilling very carefully] lol
LEDs are slowing getting wider in their light projection...
I have fitted LED downlights at home replacing the 12v 50 watt ones.
but the limited light width is a problem.. at the moment..
the 50watt ones ate 45 degrees but I have seen some now wider than that.. the LED ones are about 45 degrees..
and the warm white ones are not very bright compared to the cold white [about 1/2 the brightness and not the bright white]
I actually fitted two small down lights with bright LED lights in them..
in My Wife's Suzuki swift a few years ago.. everyone knows her car by the lights.. I fitted 12 volt zener diodes in the power to stop any over voltage [which LEDs do not like] as you know alternators can get up to 15 volts [so I've read] and My beetle shows 14 volts at times.
The early downlights are DC only and cannot work with the new electronic type of transformers, but the earlier ones can be used with a DC bridge rectifier ...
Hope YOu are feeling OK..
LEE in Scone.. bit cold today.. lol
