I have assembled another engine here using all brand new components , This 100% brand new engine will suit any beetle , any type 3 or early kombi as it is built on a universal case . This will require the use of dual carbs which can be purchased separately if required , here is a list of the components used ;
Magnesium case
Forged moly 76 mm chevy jnl crank
Forged moly 5.5 I beam rods
Forged moly light flywheel
94 mm B piston kit
Engle W 110 camshaft
Engle lifters
CNC 044 heads 40 x 35.5 stainless valves
Moly pushrods
Scat 1.1 rocker kit with swivel feet adjusters
Stainless windage tubes
Scat stainless valve covers with tabs
Billet sump plate
CB in/out oil pump
This engine is located in Wollongong NSW , and can be either picked up or I can ship Aust. wide via Toll . This engine has a compression ratio of 8.4:1 and is priced @ $ 5200 , ROD , 02-42729920 .
RodPenrose ·
