Staging brake
https://forums.aussieveedubbers.com/threads/102652/staging-brake
Stanley ·
I'm looking at installing a staging brake prior to Jambo and Warwick for the new engine. The CNC brakes look good but are a bit exy does anyone have any other options? Feel free to show your set up
SuperOwen ·
Have you already used the handbrake with the ratchet disabled? Cheapest method obviously.
dragvw2180 ·
Find a master clyinder and caliper from a motorcycle and build your own stand alone setup with a linelock installed on it . Mike McCarthy
1916baja ·
Rod has them for about 75 bucks.
FROSTY ·
I'm needing the same as I don't have a handbrake. I did see rods but haven't called him yet 75 bucks that fits the budget.
Stanley ·
I use the hand brake now for staging but i'm chasing something to lock front wheels for burnout.
hypo-vw ·
Stanley wrote:I use the hand brake now for staging but i'm chasing something to lock front wheels for burnout.
We have found using a steering/turning brake is quite effective for use as a staging brake ( both Chris Bolton and Ben Ford use them ) and as it is a dual circuit unit , it can also be plumbed to push the lever in the opposite direction also to lock the front wheels for burnout purposes , if you dont want to install an electric line locker . It would have to be plumbed from a single circuit master cylinder as it only has one inlet fitting and 2 outlet fittings
humpty ·
Been using the good old handbrake method for years, but I have upgraded to a steering brake on the new POS pan.... Mine is a total rip off of how Ben's setup is rigged on the VWMA car.... Works pretty well for him from what I have seen.... And I kinda like the idea of having some control over the brakes where you can control the amount of lock you put on.
whathaveidone ·
My Drawing not good enough for you🙁🙁🙁
FROSTY ·
Thanks Wayne, I am only running a single with back brakes only so that will be perfect.
Jason
Stanley ·
whathaveidone wrote:My Drawing not good enough for you🙁🙁🙁
Yes....it was sooooo good it made me hungry for more info. 😂
Stanley ·
Thanks Wayne...I'm running a duel circuit MC so would look at plumbing somthing into the front wheels.
FROSTY ·
Hey Stanley, Rod Penrose express mailed two of them today should be here tomorrow. Ill bring yours up to the tnt.
Thanks for sending it out so quick Rod!!
typethreeking ·
I brought a ksport hydraulic handbrake off eBay, works well
