Mid mounted gearbox support
https://forums.aussieveedubbers.com/threads/102726/mid-mounted-gearbox-support
baghall ·
Hi, bought a gearbox support that bolts to the middle section of the gearbox a while back. Was going to fit it this week but have forgotten how I weld the section to the forks and for the life mod me cannot work out how it will bolt to the car.
Can anyone help explain it with a picture please?
This the V Force / Berg type
Suppose to be page 3 of my thread
http://forums.aussieveedubbers.com/viewtopic.php?tid=36756&page=3
baghall ·
Thanks Bizarre but mine is a lot shorter and the rubber doesn't have bolts both sides' only one bolt which has me beat.
beetleboyjeff ·
It depends how many posts you have displayed to a page - it is on page 2 when I look at it on my computer Barry.
Here is a photo of mine - slightly different mounts, but basically the same.
baghall ·
Yeah both of these sit-ups have the bar past the outside of the forks but mine only just reach the outside. The hole is under the fork.l
Could it be a solid mount set up?
I've seen some that don't have any weld on bits, they just have a bump stop that hits the fork under power.
like this??
http://www.vwheritage.com/vw_spares_Gearbox-mid-mount-T2-1967-Welding-Required-AC311206_act_shop.product_pID_19642378_lang_EN_country_GB.htm
reckon it is this
http://www.piersideparts.net/LR311204.html
Only a partial pic but you get the idea. I have the mounts separate if yours didn't come with any
baghall ·
That's it Matt and Bizarre. Ok at least they are easy to fit.😂
baghall ·
BTW thanks for your help everyone. Appreciate it!
1916baja ·
I made up a couple of shims to put under the rubber so it was hard up against the frame horns all the time when I had mine mounted like that, I have since made up a new weld in one.
