Recently upgraded my turbo to a larger unit, so this turbo is up for sale.
IHI turbo (Journal bearing) (Made in Japan)
0.69 exhaust housing (ceramic coated)
Integral wastegate
7psi adjustable actuator
3" exhaust bend
Stainless Steel heat shield
Oil feed fittings included (see picture)
Comes with additional smaller compressor wheel & housing
I had the unit rebuilt with a new Garrett centre housing and all new bearings so time ago, before removing from car. I upgraded comp housing & wheel at the same time (hence smaller comp wheel & housing included)
Turbo was mounted on a 2007 cc Type 1, 960kg street car, ran a best of 12.9 sec, unit is ideally suited to 1916+ motor. Turbo is good for around 180 hp @ wheels on 20 psi. Begins to make boost @ approx. 2800 rpm
$220
Leigh, Peakhurst NSW
0419 685 738
Can deliver to Warwick in October.
vw59 ·
