engine oil
https://forums.aussieveedubbers.com/threads/102794/engine-oil
haggismuncha ·
Hi everyone, I am new to the veedub scene and just bought my first dub a few months ago. I have a 1976 microbus 1800cc. Can anyone tell me the best engine oil to use. I went to my local VW mechanic to get an oil change kit and he recommended I use Diesel 15w-40. Am not sure what type of engine oil is in the bus just now. Is it ok to use the 15w-40 to top up the oil in the meantime or should I do a complete oil change. Cheers
Ok to top up with, the diesel has been recommended as it has some good slippery stuff (ZDDP) in it that has been removed from later generation oils, there are many oil manufacturers out there with the right stuff, but I use and recommend ACE 30 (20W-40) which is Australian made/owned and designed for our air cooled engines (hence the name Air Cooled Engine oil)
68BUS ·
Matt,
Were do you get the ACE30?
I read on aircooled tech talk that they recommend using a Synthetic (or semi) 20W-50 for new engines?
Any merit in that for the first few run ins.
BTW, I got stalked the other day. When I pulled up a fella jumped out and told me he had just inherited a 71 bus.
He did not it to look nice ("just like mine🤪 ).
He did want it to go fast though. I gave him your details Matt for the engine and Dave Butler for gearbox if you don't do them.
So expect a call soon form a fella who met a fella........
Cheers mate, I don't recommend Syn till after run in preferbly, but I'm also mainly using mineral oil. Synthetic is best in trannys but keeping it inside is a problem.
I sell ACE or look on the QPL (Quality Performance Lubes, located Baccus Marsh Vic) website for a distributer or they may supply direct.
68BUS ·
Funny,
I was told Synthetic for the engine and Hypoid for the gearbox. Total reversal to you.
Alright then. You sell the ACE but you are on the Sunny Coast yeah?
Can you PM me a number so I can have a chat about with you about getting some ACE30.
Not sure I would drive all the way to the coast to get oil but my folks are often in Noosa. Maybe able to sort something out.
Cheers.
No worries, ph # is on the bottom of each of my posts
68BUS ·
Well derrr brad.
Call you later.
haggismuncha ·
Thanks, thats a great help.
bugzla ·
check out classic oils from penrite the racing series 15w50 awesome 1350 parts of zinc if you need something thicker 25w60 nulon 1500 parts of zinc
Thick oil hurts engines from lack of volume. It is the volume of oil that is the only source of piston cooling so choose carefully. Also the wider the viscosity range, the more additives hence less actual oil in the brew
bugzla ·
I don't know why people stay with mineral based oils other then rotarys with oil feed still connected, that's why they make syn products and ester blends like the racing series low vis high protection high zinc less friction more power I don't know why people are scared to protect their pride and joy... . I hear it everyday oils are oils, but I change the oil every 5 km so I can, cheap mineral in my car that's what I used for 20 years and and never hurt the engine but how ever oil manufactures never keep the same blend with base oils as they always need to make it stretch to the next model of car as matt said choose carefully
AA003 ·
Synthetic oils do not transfer heat very well and are not recomended for air cooled engines. Ring the lubrication engineers at Mobil etc.
You will notice that the oil temperature is much lower with synthetic oils as it is not transferring the heat from the engine.
vlad01 ·
http://www.bobistheoilguy.com/
Uber Kafer ·
just on the use of diesel oils in petrol engines. A number of fleet cars where I worked in the late eighties ended up with some very rattley engines. I was told it was because the fleet mechanic decide to stock and use just one oil, diesel oil in all cars, and that the diesel oil has more detergents and was stripping the bores too clean.
any knowledge on that point?
fish26 ·
Brad Penn Green Oil
Valvoline VR1 Racing
DakDak67 ·
fish26 wrote:Brad Penn Green Oil
Yup. Only the best.
Lucky Phil ·
Uber Kafer wrote:just on the use of diesel oils in petrol engines. A number of fleet cars where I worked in the late eighties ended up with some very rattley engines. I was told it was because the fleet mechanic decide to stock and use just one oil, diesel oil in all cars, and that the diesel oil has more detergents and was stripping the bores too clean.
Yep.
Did it myself.
Used diesel oil in a perfectly good 253 holden v8 (cos I got the oil for nothing) and ended up with noisy lifters.
Also saw several perfectly good engines ruined back in the 80's when Teflon treatments were the go.
Turned out the Teflon treatments were chockabloc full of the same detergents, and stripped all the carbon and varnish out so the Teflon could attach itself to the metal.
Turned them into noisy old oil burners.
vwo60 ·
http://www.aircooled.net/synthetic-vw-oil/
http://www.lnengineering.com/joegibbsracingoils.html
I have been running penrite in all my engines but i will try the Joe Gibbs DT50 at my next oil change
bugzla ·
just putting it out there.................... with the vw motor it's air cooled not oil cooled correct
DakDak67 ·
Both.
vlad01 ·
vwo60 wrote:http://www.aircooled.net/synthetic-vw-oil/
DT50 will be the best, Raby developed that oil with Joe Gibbs company.
Make sure you use Joe Gibbs run-in oil first for little bit to flush the old oil, then DT50. Otherwise the chemistry clash will do harm.
Also penrite released 10 tenths "premium" range.
over 1600ppm zinc and class 5 and 4 synthetic esters, not just class 4.
Will see if I can get the HTHS rating as well, might have to email them for it.
vlad01 ·
matberry wrote:Thick oil hurts engines from lack of volume. It is the volume of oil that is the only source of piston cooling so choose carefully. Also the wider the viscosity range, the more additives hence less actual oil in the brew
if its synthetic it will have a wider range as synthetic base stock is more stable over over a greater temp range than mineral.
so if its fully synthetic, regard the wide range as good, if its mineral and wide range, stay away.
bugzla ·
found that lucas also make a syn and mineral based oil for the trusty vw ive just purchased a infra red temp gun so ill do some testing in a couple of weeks on head temps between mineral and syn oils lucas could be donating a bottle for me to try in the trusty buggy so I use that as a starting point as for the zinc massive amount
vlad01 ·
bugzla wrote:found that lucas also make a syn and mineral based oil for the trusty vw ive just purchased a infra red temp gun so ill do some testing in a couple of weeks on head temps between mineral and syn oils lucas could be donating a bottle for me to try in the trusty buggy so I use that as a starting point as for the zinc massive amount
only way to be sure is do a UOA on the current oil for reference.
Use break in oil from the new brand, then do a UOA after say 2 oil changes with the new oil.
you will see if its better or not once you get the results back.
bugzla ·
Mobil 1T V-Twin 20W-50 anyone used this ............................. sounds good I asked the mobil tech guys they recon this is the go a bit weird cause when asked a month or so ago they said no to syn oils interesting
Newt ·
Guys
If you used Joe Gibbs break in oil, can you switch to other brands after?
Newt
