Bizarre wrote:My wife has a 2008 NB and the headlight stopped working on the drivers side.
No parker, main or high beam.
I had a new headlight put in on the passenger side a few months back as #3 clipped it and broke the lens in a driving lesson.
99% sure all was OK when we got it back
Passenger side works.
Fuses are fine - but you aint going to blow 3 fuses.
Ideas??
Hi the only usual connection that all 3 lights use , apart from a plug would be the earth...
sounds like it didn't work when You got it back from the headlamp repairs.. I'm not sure on late VWs but all japanese cars have relays and fuses in a box under the bonnet usually near the battery... whether a plug has come loose there.. or a plug has come loose somewhere else.. maybe near the replaced headlamp..?? Heaps of plugs on new cars but they don't just come off by themselves, and are usually hard to pull off.. so unless its an earth issue... and as You said, 3 fuses wouldn't blow... see if You can see wires going from that headlamp to the main wiring loom.. maybe it was unplugged to fix the other headlamp??? and not plugged correctly back in and has come apart enough to not make contact... but could look like its plugged in...
best of luck
