WTD Engine Hatch and suround Brisbane Area
https://forums.aussieveedubbers.com/threads/102900/wtd-engine-hatch-and-suround-brisbane-area
68BUS ·
Does anyone have an Engine Hatch and surround available in the greater Brisbane Area?
bushed ·
yes, but what for, 74, 73 here
68BUS ·
Does not matter.
I want the lid and the surround supports to fit it into the back of a splitty bus.
My new motor has a turbo fitted up top and a side draft carby. Both of which sit higher than the current fly wheel tinware but also higher than the sheet metal of the rear parcel shelf.
I plan to put in a 50mm raised box and then sit the engine hatch and surround onto that. To give me access to work on them as well as fit them.
If that makes sense.
I would be very interested in a 73 or 74 if you have them. Especially if the surrounding metal is available too.
It just makes it easier for mt to fit and get air tight as well as being able to buy an off the shelf rubber seal for the lid for noise and fumes.
bushed ·
yepp, surrounds are all very gd
may trade some other bay bits esp slider rubber?
am hme 2 day if you want to get it or cut till late m8
04212 86423
bushed ·
i need a 12vlt 1600 starter btw
68BUS ·
Thanks Bernie.
I will give you a call later.
And you cleaned me out of Bay stuff the other day. The few items you didn't take I put on ebay to get rid of.
Not sure I have anything left now.
Apart from those wheels you saw out the back of my house.
If I can think of anything else I have kicking about I will let you know.
Brad.
bushed ·
sorted? whole back panel avil if u want Brad
B
