bolts removing engine
https://forums.aussieveedubbers.com/threads/102915/bolts-removing-engine
brujo ·
Hi- i've got a 66 beetle with a 1200 motor and want to remove it and do some big rust repairs then put a tp 1600 motor in. are there 4 bolts around the bellhousing and then the heat exchanger bolts? Its pretty grotty under there and can't seem to find the bottom bolts? Will the 1600 tp motor fit?
Trev
grumble ·
Scrape some of the 40 years of accumulated glug off near the bottom of the bell housing and you will see the 2 17mm nuts,the 1600 twin port will fit but you will have to clearance the bell housing to fit the flywheel in.
hellbugged ·
Yeah 4 bolts
Bottom 2 nuts up above the rubber engine mounts
Top one behind clutch lever and other side accessed from engine bay down behind fan
Heat exchangers should be able to just slide the plastic tubes that connect them to the body out of the way. Loosen and slide the control cables out
Disconnect coil, choke, fuel solenoid and large battery wires from regulator
Disconnect fuel line and accelerator cable
Remove rear engine tin breast plate
.....flywheel on 1600 may be bigger, but easily overcome
brujo ·
thanks-it's my first engine pull- i may just put it back in for practise -i've already removed the valance-going removable
thanks again
Trev
