external oil filters
https://forums.aussieveedubbers.com/threads/103122/external-oil-filters
sikras ·
Hey peeps, can any1 help in directing me for an external oil filter kit. I got '64 beetle with a 1300. I ask cause i opened the oil cap today and saw heaps of white gunk. I know it's huidity(moisture), however can any1 tell me where from ?
nils ·
I usually get it if I only do show trips and dont get the engine warm enough,
not enough hot driving to get the moisture out of the oil
Need to get the oil temp up above 100
Dont believe an oil filter will help here as water would just pass through
The moisture is in the air that gets inside your engine. Once shut down, the hot engine begins to cool, as it cools air is drawn in (hot air expands, cold contracts). The moisture gathers in the oil cap as it's the coldest place and only gets burnt off with sustained engine running. So with lots of short trips the white sludge forms which you can just wipe out as a filter will not make any difference to the issue.
sikras ·
Should i take the oil cap off after every use ? u guys think it will help ?
sikras ·
Also i want the external filter not just for the water factor.
Governor ·
One of the best oil filters I have used is an Oberg, washable and you can adjust the filter size, not that I have ever done that
