Beetle IRS rear shocks , use for mock up car and been hanging in my shed ever since $ SOLD
Period Bullet drivers side mirror $SOLD
Late sixty's horn button $ GONE
Alloy type 1 rocker covers , good thick ones , sorry no long nuts or bolts but you can buy them at any good bolt shop as booker rod joining nuts $SOLD
German early hub cap clips $2 each or the lot for $10
Early beetle fuel guage panel $free
4" Peep mirror , obviosly a bit ratty so would look good on a rat , stainless steel is all good $GONE
36 DRLA delollorto carby and centre mount manifold , was on my 1600 dual port in the Rat Racer for a couple of years and it would be happier on around a 1776 as it struggles with low air speeds at idle but would be fine on a 1600 with some 26mm venturies compared with it's currently fitted 28mm . $SOLD
Beetle gearbox front offroad strap , is missing the 2 little outer tabs but they are only pieces of flat bar with a 12mm hole in them $ GONE
Beetle b pillar grab handles / ankle straps 馃槀 $ 5.00
Volma beetle seat recliners , these attach to the side frames of early beetle front seats and let the rear swab lay flat and turn the inside of your beetle into a bed , sorry there is only 2 out of 4 of the plastic end covers $SOLD
Yokohama Geolander AT/S tyres , were on my Tow'ds front rims for about a month and as the car is not drivable yet they have done zero road miles ,size is 205/ 70 / 15 which is a good size for the front of a dune buggy or baja with a rolling dia of 675mm $SOLD
Oval beetle steering box , this is a nice tight box that was removed from the Towdster in 2004 and hasn't been used since , and they make for a way tougher steering box for offroad use or if your just looking for a good steering box for that oval resto $SOLD
2 off 6 volt beetle battery covers , first in gets the good one $5 each
CAV fuel filter and water seperator SOLD
Bay Kombi booster fan SOLD
091 2lt Kombi Gearbox / Transaxle , have been hanging on to it as a spare for our Baja Bus , was told it was a good driving box when i bout it in 2009 but have never fitted it . SOLD
All items are located at Alexandra Hills Qld 4161 and as i work all over SEQ and have a tray back delivery is not a problem for a few beers etc , and i am happy to post interstate at your cost .
Contact details :
Andrew 0411556744 or PM here
OZ Towdster 路
