Just doing some studying in the manuals. I will soon be assembling a long block. I'm on a budget and so can't afford a specialist to assemble, however as a graduate engineer i think its my obligation to learn the workings hands on 馃檪.
Engine is 2054cc Alum case, 74mm CW crank, 94 P&B's, SP heads (39x35.5mm), CT26 turbo, dual 32DIS Solex carbs, Scat C25, magnaspark II dissy. Wierd combo, but goal is torque monster for baja, with turbo to 'pick up' the typical SP top end drop off and extend the power curve.
For a non-stock engine, should factory torque specs still be adhered to for all studs/fasteners? Or should greater torque be applied in some instances?
I read that case studs should be installed 'finger tight' only. Is this all? no torquing with wrench what so ever?
Thanks,
Chris 馃檪.
Build to come on here soon! Rotating assembly is at Crankshaft ENgineering Browns Plains at the moment and heads at mick motors getting some work.
bajachris88 路
