Hi All,
I am selling my 2387 Long block as the Barny is a long way from finishing detais as follows.
New: alum. case
New: chromoly 86mm crank
New: chromoly 5.7 H-beam rods ( Chevy )
New: SLR cam .255 @.050 .589 lift w/ 1.4
New: Scat Lub-a-lobe 30mm lifters
New: Cima pistons with Jaycee barrells and Grant rings
New: 30mm oil pump
New: Doghouse cooler
Fred Simpson's V-7 heads( welded , P&P) 44x37 stainless
valves,Bugpack
dual springs,chromoly ret. and keepers re-done by AJ Sims
Compression is 8:1
New: external oil cooler with fan
Thin line sump
The motor was built by AJ Sims.
Also I have a DMT fan shroud I will throw in
The engine is located south side Brisbane 4113
Price $6500 OB
Contact: Cameron
my phone number is 0439768168
thanks,
Cameron
666bug ·
