pete wood ·
What is the factory torque figure for rear axle nuts?
https://forums.aussieveedubbers.com/threads/103245/factory-torque-for-axle-nuts
pete wood ·
pete wood ·
Allbones ·
pete wood ·
HappyDaze ·
And tighten nut to the next split-pin slot....don't back it off.🙅pete wood wrote:Ok, so that is me on the end of a 300mm bar. Just as I thought.
What's the maximum?
vlad01 ·
looks like I would need to use a pipe on the torque wrench then. I am no where near that heavy lol.pete wood wrote:Ok, so that is me on the end of a 300mm bar. Just as I thought.
What's the maximum?
have sent You a PMAllbones wrote:To save starting a new thread, does someone want to let me know what the front stub axel torque setting is? Cheers 🙂
pete wood ·
That's what I thought. 👍HappyDaze wrote:And tighten nut to the next split-pin slot....don't back it off.🙅pete wood wrote:Ok, so that is me on the end of a 300mm bar. Just as I thought.
What's the maximum?
HappyDaze ·
That's easy for you to say.😂1303Steve wrote:Hi
I can do 217 ft/lb with one hand.
HappyDaze ·
silver ·
and the other on his wrenchCraig Torrens wrote:Steve always uses one hand on his nuts 😉
waltermitty ·
Steve what lube do you use?silver wrote:and the other on his wrenchCraig Torrens wrote:Steve always uses one hand on his nuts 😉
1500S ·
If you are using a torque wrench it wouldn't matter if you used a 3 metre bar on it!! It will still only register the maximum torque it's designed for otherwise it will be damaged. If it's designed to do 217 lbs ft then the length of handle should be long enough one would think for any adult.vlad01 wrote:looks like I would need to use a pipe on the torque wrench then. I am no where near that heavy lol.pete wood wrote:Ok, so that is me on the end of a 300mm bar. Just as I thought.
What's the maximum?
pete wood ·
1500S ·
Yes Pete. Good to see you are still playing with VWs Pete.pete wood wrote:300mm = 30cm = 0.3m or 1 foot. 😉
P.s. is that you Dallas?
pete wood ·
vlad01 ·
yeah I mean I wont even be heavy enough to reach that torque with standard 300mm length of the torque wrench. but with the trailing arm removed and a safe means of holding the stub flange in a vice, one can pull that torque fairly easy. After all everyone is stronger than their body weight. But doing it on the car will require a longer handle or a pipe.1500S wrote:If you are using a torque wrench it wouldn't matter if you used a 3 metre bar on it!! It will still only register the maximum torque it's designed for otherwise it will be damaged. If it's designed to do 217 lbs ft then the length of handle should be long enough one would think for any adult.vlad01 wrote:looks like I would need to use a pipe on the torque wrench then. I am no where near that heavy lol.pete wood wrote:Ok, so that is me on the end of a 300mm bar. Just as I thought.
What's the maximum?
1500S ·
Vlad, I sincerly hope that you have more mechanical knowledge than you suggest by using an extension bar on a torque wrench due to the fact a torque wrench 400mm long is usually only around 120 ft lbs (Warren and Brown type). By doing that will only damage it. The only way to increase the torque with a small scale torque wrench is to use a torque multiplier............. but you are surely going to tell us that you knew that and just meant you were going to put a piece of pipe on a socket/breaker bar to reduce your effort to tighten the 36mm axle nut.vlad01 wrote:yeah I mean I wont even be heavy enough to reach that torque with standard 300mm length of the torque wrench. but with the trailing arm removed and a safe means of holding the stub flange in a vice, one can pull that torque fairly easy. After all everyone is stronger than their body weight. But doing it on the car will require a longer handle or a pipe.1500S wrote:If you are using a torque wrench it wouldn't matter if you used a 3 metre bar on it!! It will still only register the maximum torque it's designed for otherwise it will be damaged. If it's designed to do 217 lbs ft then the length of handle should be long enough one would think for any adult.vlad01 wrote:looks like I would need to use a pipe on the torque wrench then. I am no where near that heavy lol.pete wood wrote:Ok, so that is me on the end of a 300mm bar. Just as I thought.
What's the maximum?
pete wood ·
vlad01 ·
umm? no I 2 have W&B wrenchs one micro and the big one goes to 220ft, even with 100 ft-lb bolts I do up I am putting a lot of force to get to it, typically leaning back with both arms on it.1500S wrote:Vlad, I sincerly hope that you have more mechanical knowledge than you suggest by using an extension bar on a torque wrench due to the fact a torque wrench 400mm long is usually only around 120 ft lbs (Warren and Brown type). By doing that will only damage it. The only way to increase the torque with a small scale torque wrench is to use a torque multiplier............. but you are surely going to tell us that you knew that and just meant you were going to put a piece of pipe on a socket/breaker bar to reduce your effort to tighten the 36mm axle nut.vlad01 wrote:yeah I mean I wont even be heavy enough to reach that torque with standard 300mm length of the torque wrench. but with the trailing arm removed and a safe means of holding the stub flange in a vice, one can pull that torque fairly easy. After all everyone is stronger than their body weight. But doing it on the car will require a longer handle or a pipe.1500S wrote:If you are using a torque wrench it wouldn't matter if you used a 3 metre bar on it!! It will still only register the maximum torque it's designed for otherwise it will be damaged. If it's designed to do 217 lbs ft then the length of handle should be long enough one would think for any adult.vlad01 wrote:looks like I would need to use a pipe on the torque wrench then. I am no where near that heavy lol.pete wood wrote:Ok, so that is me on the end of a 300mm bar. Just as I thought.
What's the maximum?
I actually know what it took to undo the axle nut on Pete's buggy axle a couple of years ago, no doubt caused by someone (not Pete!) who didn't have a clue on what torque was being applied to the nut.
HappyDaze ·
Me too.....even on the 356 drums.👍matberry wrote:Well, just to throw a spanner in the works, I use somewhere closer to 350-400 ft/lb as 217 is not enough in the real world. In the trade doing nothing but ac VW's, if I used 217, I would go broke replacing flogged out drums.
vlad01 ·
that's a good point, I always thought if it was necessary for more than the factory spec?matberry wrote:Well, just to throw a spanner in the works, I use somewhere closer to 350-400 ft/lb as 217 is not enough in the real world. In the trade doing nothing but ac VW's, if I used 217, I would go broke replacing flogged out drums.
HappyDaze ·
pete wood ·
Ok, but at what point are you just stretching the axle threads?matberry wrote:Well, just to throw a spanner in the works, I use somewhere closer to 350-400 ft/lb as 217 is not enough in the real world. In the trade doing nothing but ac VW's, if I used 217, I would go broke replacing flogged out drums.
I guess over 400, not sure really as the OG nuts and axle threads are very rarely an issue.pete wood wrote:Ok, but at what point are you just stretching the axle threads?matberry wrote:Well, just to throw a spanner in the works, I use somewhere closer to 350-400 ft/lb as 217 is not enough in the real world. In the trade doing nothing but ac VW's, if I used 217, I would go broke replacing flogged out drums.
vlad01 ·
awesome, thanks.matberry wrote:Always a lubed thread. I've said it before and I'll say it again, up to 700% increase in clamp force between dry and properly lubed thread and washer.
