Aussieveedubbers 路 Tech Talk
Uni Joints for Shifter
https://forums.aussieveedubbers.com/threads/103396/uni-joints-for-shifter
Smiley 路
Hey all.
I'm chasing some uni joints for the shifter in my Baja. I've seen on Formula Vee racers that they use unis to go to the back of the car and around the box. Does anyone know where I can get some of these?
Calling all Vee owners/builders, if you could chime in here that would be great.
Smiley 馃檪
vwo60 路
i have seen super bug steering uni joints used in that application, they are about the right size.
cnfabo 路
http://www.google.com.au/search?tbm=isch&sa=1&ei=B3ksUonxJYm8kAXo-IHoBg&q=uni+joint+with+rubber+boot&oq=uni+joint+with+rubber+boot&gs_l=img.3...47712.53641.0.54053.17.17.0.0.0.0.423.2815.6j4j1j4j1.16.0....0...1c.1j4.26.img..16.1.353.sTlWajOVPhM&biw=1280&bih=752&sei=QHksUor9EsLulAXf3ICICA#biv=i%7C31%3Bd%7Cm7aYtYmIDnaF_M%3A
Is this what you are talking about
nils 路
Yeh, any small uni joint works there's nothing special about them.
HappyDaze 路
Mollart joints.
vlad01 路
I used a commodore steering column uni in my buggy few years back. I recall it was a real simple mod to make it fit, something like just using the stock holden R&P coupling clamp and an additional hole drilled/tapped for the locating screw from the VW stock coupling. worked well.
