In my daily driver, 1969 beetle. As I accelerate there is a knock that comes thru the floor, no matter how gingerly I let the clutch out or depress the accelerator the noise is there and loud.
So what am I looking at?
Front transmission mount?
Thanks for any responses..
LUFTMEISTER ·
yep or even the gearbox mounts on the cross member have gone soft or separated.
takis ·
Thanks, for the response.
So does this require engine removal , in order to replace the nose one mount?
yes and no
You can just loosen the bolts on the gearbox brace to move the whole thing back far enough
I was able to change mine this way - but it died in 6months any way
Then I put a Porsch style Berg mid mount on and that fixed the sucker
rear mounts mean engine out as you need to get inside the bell housing
shokwave2 ·
Definately check the front tranny mount. Mine was doing the same. If its worn replace it, or maybe the bolts have loosened and just need tightening.
empi ·
Check all shift rods also and the coupling under the rear seat
