vw beetle rat rebuilt $1500
https://forums.aussieveedubbers.com/threads/103425/vw-beetle-rat-rebuilt-1500
flat rat dak dak ·
fantastic rat
1959 beetle pan with 1966 (i think)body shell
ground up rebuild
new floor pans painted in por 15
no rust in body except lots or rat style surface rust treated with ankor wax
new pan rubber
new heavy duty engine and gearbox mounts rated to 300hp
gearbox run perfectly
new window rubbers for all windows
new brakes including new lines and master cylinder
lots of stainless bolts used
new wiper arms
new clutch and accelerator cables
new tierod ends
new swing arm gearbox boots
honda prelude front seats standard rear
new headlights
reco fuel tank
new front wheel bearings
por 15 on all body under surfaces
tunnel cut with lid for easy clutch cable access
new battery
needs some finishing off (electricals namily rear lights fuel sender running boards some interior bits and pieces )
$1500 Without engine or $4000 with the following high performance engineType 1 1916 turn key engine. $2500
Less than 1000km old
professionally built with all new parts which include
- New Cb performance alloy case (over $1200 to buy)
-New heads fitted with K liners for longer lasting and larger inlet valves-
-Powder coated tinware
-New 94 mil barrels and pistons
-con rods shut and cut and re-balanced
-Cam followers re-cut at one degree tapper
-Stainless steel push rod tubes
-New exhaust systems and new J pipes
- New 110 cam
-new 12 v flywheel and clutch
- new twin 34 ml carbies
-Large oil pump
-009 distributor
-New oil cooler
-All new bearings
hear running in car
runs perfectly
pictures to come soon
Bargain at $2500
no rego
a bargain
located in Forster nsw
ring tony on 0417017246 or 02 65592417
okrasa power ·
Ok done deal
See you soon
Mikki
esevwbits ·
keen if not already sold...
flat rat dak dak ·
sold to micky... pending payment
benny_acko ·
Damn..let me know if the engine purchase falls through
flat rat dak dak ·
sold sold sold
1966 type 3 ·
what a bargain all seemed to cheap to be true
