tweety wrote:About 10 weeks ago my engineer replaced a rear wheel bearing. Torqued it up to the specs from memory over 200 lbs even near 300. whatever it was.
The swing arm is Panther custom one. I had a new axle on hand as well as the new bearings. Today I had my Cv boot repalced and my mechanic inforemd me that there is slop in the wheels bearing. couple of mm's.
Why would this occur? Whenever I've had one replace dits lasted 10 years or more. What would cause this?
If its an IRS rear end similar to a beetles, there is a spacer between the bearings, which causes the problem of play over time... [slop] from what I have read..
a mechanic who did My rego check a couple of years ago mentioned it.. naturally it wasn't a couple of mms.... even if measured at the top of the tyres..
Ask your Mechanic if He uses Lithium based Moly grease -[ a Blackish grease] as per VW manuals.. or the green clay based grease which I wouldn't use on a push bike.. ? The lithium based Moly grease WILL make CV Joints and bearings last a very long time... but they need to be packed fully too.. which is quite messy with lithium based grease..
apart from that, the most important thing is the brand of the bearings... also if the correct high load bearing is used, as many people just use two cheap ball bearings as they are much much cheaper than the expensive roller bearing used on the outside..
also the inner ball bearing which [like a 6206C3 or 6306C3] should have no seals on it as there is only a very small amount of green grease inside those.. and filled with lithium based MOLY grease.. it also needs to be a C3 bearing.. The original outer bearing is expensive like an NU206 or NU306 and also needs to be well packed with lithium grease.. The rear axle nut torque is 217 ft lbs..
Now how You are going to find any of this information out..
I don't know....
I know that I have cleaned and refilled My original Bearings and CV Joints with Lithium based Moly grease back about 2003 in My 68 semi auto Beetle that has the CV Joint rear end... I also know they will last for a very long time due to the lubrication...
I can only suggest You ask for the 2 old bearings He is going to replace to check what bearings were used and what grease was used.. CV joint boots usually show surface cracks long before they actually rip apart.. I replaced two of mine when they first showed signs of cracking...
Best of Luck
