Window stuck
https://forums.aussieveedubbers.com/threads/103526/window-stuck
1blue51993 ·
My right side window is stuck in the door frame. The Glass is no longer attached to the lifter?/ guide the raises and lowers the window. Any ideas on how to loosen the window without breaking it? Cheers. Also the rubber guide near the edge of the door-should that be infront or behind the metal as the screw is missing, thanks!
Can you still wind the handle up and down and the lifter moves??
The glass only sits in the lifter and is held in place with some rubber at the bottom.
You said this car has sat for a while - i am guessing the glass has frozen in the bailey channels and is stuck there.
As said - it doent take much to pull the glass out of the lifter thing
maybe a bit of WD40 round the outside of the glass, even run a blade down the side of the glass.
then apply pressure either side of the window and push down
Good luck
1blue51993 ·
The lifter still works, will try the WD40. Bloody annoying tho!-thanks
silver ·
I can see a bolt missing in the side channel guide, I could see that making the window tight
1blue51993 ·
could one bolt missing jam the entire window>? looking up at the window winder mech it looks like its slightly bent around the 3/4 vent post, is that normal?. Might have to look at the other door and see if there is something different..
silver ·
1blue51993 wrote:could one bolt missing jam the entire window>?.
yes that channel looks too be leaning in about 15mm i am certain that would make it tighter
1blue51993 ·
just took card off left hand door and the chanel/guide is in the same position and window works. However when i look up at the winder mech I cant see it, where as drivers door I can, thinking its been bent and thats why the glass cant get past it?
Might need a new regulator thingy??
I have sent you a PM..
looks like the glass has come out of the bottom channel..
maybe the channel has rusted out...
1blue51993 ·
Thanks Lee, PM sent to you-cheers
