Has anyone had child seat anchor points installed in a bug? If so, what's involved and roughly what did it cost? ('71 Super in case it makes a difference...)
Marco
Marco_VESS ·
Aussieveedubbers · Bugs
https://forums.aussieveedubbers.com/threads/103539/child-seat-anchor-points
Marco_VESS ·
barls ·
Marco_VESS ·
barls ·
pfillery ·
To directly answer your question, I've seen them fitted in a couple of places, either just under the rear window, bolted through underneath the grilles (technically a lot more involved to do) or in the bottom of the luggage area behind the rear seat (easier). Really depends on your local laws. In Qld you can fit them yourself as long as you do it according to regs and get it inspected and plated. IE you don't need to "have it fitted by a qualified person". You need to use a certain size bolt and a plate with welded nut, riveted to the body etc.Marco_VESS wrote:Has anyone had child seat anchor points installed in a bug? If so, what's involved and roughly what did it cost? ('71 Super in case it makes a difference...)
Marco
bnicho ·
