sydney shed cull - beetle stuff
https://forums.aussieveedubbers.com/threads/103553/sydney-shed-cull-beetle-stuff
whatnowthistime ·
all prices unless otherwise noted as $ are in coopers pale (the green one). i'm also open to swaps for stuff I need/will need. (suit 56/63's)
everything is in Wahroonga Sydney NSW Australia 2350 near 33°43' 06" S 151°07'07"E.
i'm henry.
sorry pickup only. i'm very short on time.
please pm me (and include your ph number if that's best for you) as i'm not near a phone most of the time...
my contact number for some of this week and next on some evenings is 9489 3603 please ask for henry. as said above though, I won't be near a phone most of the time so please pm me.
I can possibly deliver to points up the New England hwy or Armidale via Gloucester in the next week or so for beers.
if you are super desperate i'll get pics of the bigger stuff, otherwise just visualise stuff that was pulled off cars in the 90's and shoved in a shed till now.
12V BEETLE ENGINE
1 AS41 short block thin stud for rebuild, AD prefix. I can probably dig out nearly everything else bar the cylinders, fan shroud, heater boxes and exhaust if the offer is good enough to spend the time. offers or $ 400 with the extra stuff.
I will consider swapping for 36hp , 40hp or 1300 single port performance stuff. pending as a short block.
assorted 36hp-1600 crank pulleys. beer/s depending.
assorted generator stands. 1 or 2 longnecks depending.
assorted flywheels. 12/13/15/1600. beers/$ varies with which type
whatnowthistime ·
12V BEETLE OTHER
rear seat ex 68? off weiss basket weave, very dirty, from memory no holes. 2 longnecks
68 engine lid, no vents. bogged dent in bottom drilled for "VW automatic" script. $20 or beers.
S model superbug? highback seats on runners (NOT 3 point mount) dark red, drivers has a hole in the right shoulder otherwise good. $30. SOLD
12V 1500 beetle glass. 2 longnecks for all I have. I think I have both screens and both rear 1/4's but will need to check. now including fulysik 80's tint job.
whatnowthistime ·
6V BEETLE ENGINE
1 36hp manifold heat risers blocked but not rusted through. $ offers (i'm not sure I should sell this....)
assorted 36hp tinware. sorry heater boxes accounted for. beers or $
36hp engine case. 2689565 november? 58 no head studs. cleanish. plenty of surface corrosion on the inside but has been given the visual ok by a vw specialist. offers
40hp manifolds. blocked but not rusty heatrisers. $25
1200/1300 sp fanshrouds, 2 of, 2 longnecks ea
assorted 1300sp tinware. beers or $ depending on what.
1 1300sp manifold. decent condition. $25
6V generators and starters. 75% were pulled from working cars by me. but nfi which ones so it's a lucky dip. 😂 $10-25 depending
assorted 36hp-1600 crank pulleys. 1 longneck up
assorted generator stands. 1 longneck up depending.
assorted flywheels. 12/13/15/1600. no good 36hp.
whatnowthistime ·
6V BEETLE BODY ETC.
56-59 fuel tank has some rust holes around the pick up (localized) with cap and fuel cock $45
65-67 engine lid, has rust in the bottom inner and a little on the outer. $45
60's pass door, complete. a little rust under the 1/4 window, otherwise good. $70
rear seat black (vinyl spray?), ex 67? 2 longnecks.
60-67 steering wheels. 1 inc unbroken horn ring, minimal cracks no horn button $50 (pending), 1 bare in fair condition $25.
6V bumper over rider stuff. $5 or beer up depending.
front seat base. screw backrest style circa 62-7???, can't see any broken springs but I didn't look too hard. $25 or beers.
6V big window glass (no sekurit or duroglas), most with stainless or alloy trim. HEAPS. 1 longneck per bit (or 3 per back window) or less for bulk. if you want specific date codes tell me how to identify it and i'll look.
more to come as I get to it.
whatnowthistime ·
one last post to make 5 and hopefully I can now sent pm's.
jr232 ·
pm sent
57 oval ·
Legend, dealing in real currency! Best of luck with your clean up
whatnowthistime ·
I missed a section when I cut and pasted it...
6V BEETLE SUSPENSION ETC
split case gearbox case with nosecone/hockeystick. A2485912 circa late '59. beer/offers.
splitcase gearbox diff bits and axle/s? free.
linkpin beam, spindle to spindle. $75
linkpin beam early with no steering damper, no steering box otherwise complete drum to drum. (pending)
linkpin trailing arms to drums set up L and R $35 or beers.
6V rear springplates $20 or beers.
6V rear torsion arms. 1 longneck.
6V brake parts, drums, backing plates, internals etc. $2 up or beer/s depending.
whatnowthistime ·
but wait there's more.
1500 beetle (I think) footwell plates. L and R. the left is decent, the right one is rough. 2 longnecks/offers?
engine lid U shaped hanger thingy's (that go between the engine lid and the body). several pairs. a longneck per pr.
bonnet hinges. ex '60 2 hinges and the latch, $25. later 6V sprung ones. a longneck.
assorted 6V big window wiper motors. screw terminal (58-62?) $ 25, spade terminal (63-67) 2 longnecks, a random one that is the same width as the others and the frame/arms look the same but has a round bodied 12V motor fitted $20
stock swaybars. no clips. a longneck ea.
1300 sp engine case. F1148105 $30 (bring a box as it's FILTHY)
watch this space... there's more to come.
I might pop around....we can have a little chat about some Melburg Luft posts that you have made.
whatnowthistime ·
sure, if it fits your work schedule daytime is the best time to catch me there.
edit, if not, call the number in the post and we can try to arrange a time to catch up.
GottaSplit ·
Got any 60's bumpers front and rear?
whatnowthistime ·
I have some rear hoops and over-riders, but no bars.
whatnowthistime ·
offers?
i'm about to give some friends a pick over then the scrappy gets what's left.
SuperOwen ·
I'm still good for the steering wheel. 👍
whatnowthistime ·
actually, you'll be getting both steering wheels. 😂
btw, that's a lovely std model as your avatar.
cam070 ·
I'll take that 68 onwards engine lid. Can organise pick up around 530pm or 8am on weekdays
whatnowthistime ·
pm coming your way.
SuperOwen ·
Thanks, that's where the wheels going.
fish26 ·
Hey Henry, how many 12 volt flywheels have you got, would be interested.
ben
0413 333 833
GottaSplit ·
is the horn ring still available?
whatnowthistime ·
sorry the horn ring is going with the wheel(s)
