Item: CB Perfomance Los Panchito head X 1 94mm
Item Condition: used for around 500klms
Reason for selling: 90.5, long story
Price and price conditions: $350
Contact: Ian 0404874097
INFO>>>>> I was sent a 90.5 and a 94...so after much stuffing around they sent me some shims to suit the 94 for the time being and since then I was finally sent the right sized head....
Extra Info:
With 40 x 35.5mm Stainless Steel Valves, CNC Porting, Dual Hi-Rev Springs, Chromoly Retainers, & SUPERGRIP™ Valve Locks. 94mm Bore.
The Los Panchito CNC Ported heads will give you the power you need at an affordable price. Extreme port velocity results in amazing air flow from only a 40mm Intake valve.
Capable of producing over 160hp, the Los Panchito is the 'best bang for the buck.' Due to the small intake port volume, the Los Panchito will provide unsurpassed low end power. Perfect for engines as small as 1776cc or big as 2332cc! Combustion chamber volume measures in at 59cc. Available in 90.5/92 and 94mm bore sizes. Also available are the choice of single or dual valve springs. Uses 14mm Standard Reach Spark Plugs.
binner ·
