Ebay: http://www.ebay.com.au/sch/bajabaja1969/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
(See at bottom of thread for ebay details)
I'm selling up excess stock taking space. Postage welcome but at buyers expense. I prefer pickup on larger items. postage will be performed once a week, on a saturday morning excluding this weekend. Pickup can be organised for after hours.
Prices as below (doesn't including postage). If interested and making an inquiry, please state the item number 馃檪.
Seller: Chris Leete
Contact: PM inquiries on items here, or text to organise call on 0402 568 003 (preferrably after hours).
First in first serve.
vw parts sale
ITEM # | DESCRIPTION | COST
3. 2 x heater boxes. Unknown condition. $10 pair.
4. Single port manifold, complete and orig. Suspect 1300 or 1600. You decide. $10
5. Type 3 fan and housing. $10
6. 2 x baja rear guards. super thick fibreglass. holes cut for new beetle tail lights, requires finishing for light mounting. $20 pair
9. Beetle tie rod. assume 1500 series. end to end. $5
11. Type 3 generator, it was working long time ago. kept wrapped up in tarp outside. needs a clean. $15
14. 69' 1500 original windscreen washer bottle. $10
15. Misc carbs, need rebuild/clean up, complete to partial (31pict2, 28pict, 32-34PDIST2 x 2 (pair, was working), 34pict3, holden stromberg) $5 each
17. 1 x tomb stone tail light for bug. with reverse lamp. assume early 70's. $10
18. 1 x brand new universal water temp sender mount, for plumbing in series. $10
19. 1 x brand new aftermarket air filter mounting bracket. Bend to suit your application. $5
21. 1 x toyota plastic air filter box. Can adapt to upgrade filter. Good for aftermarket engines. Can plastic weld (as per smiley's baja thread) $10
22. 1 x brand new 4wd tow hook. rated at 4000kgs and chrome. comes with bolts. Mount into baja or buggy barwork etc. $10
23. 67' Bug fuel gauge and surround trim. Unknown condition $10
24. 67' bug window winder and door handle (ice pick) $5
25. bug windscreen wiper. Either 67' or 69'. You decide. $10
27. 67 bug window washer pump. This is the bladder model. Bladder rubber cracked open. $5
28. Brand new roller pedal for bug. LHD though. Possibly mod to suit RHD? $5
29. Quick shift mount for type 1. Doesn't include lock out plate (stock suits), or little ball ball thingo that sits on stick. $2
30. Universal battery clamp. You decide if it suits your application. $5
31. Misc 1600 single port engine bits. All need cond. $15 each (crank, case, heads etc). Cam $10
32. 1 x brand new vw upright alternator. Chinese. Unfortunately, they forgot to machine a keyway for front pulley, Otherwise fine. $35
33. 1 x genuine bosch vw upright alternator. spins freely, not sure if internal or external regulator, needs brushes soldered in. $20
34. 1 x vw 1600 12v generator. spins freely. thread at pulley needs tidying up $25.
36. 67' or 69' bug door interior handle surround. Chrome. good nick $5
37. 1 x distributor waterproofing kit. suits 009 style (no vac advance). like a condom, brand new/silicone. needs tidy up. $5
38. 1600 twin port manifolds $10
39.69' 1500 series heater pipe (bakelite? + metal mesh bit from under seat). is only 1 side. $5
40. 67' bug headlight switch. $5
41. brand new Early style clutch throw out bearing. in box. $15
42. bug? cv joint. $5
43. brand new bug handbrake boot. Needs serious cleaning from overspray. Heater lever holes cut roughly $5.
44. Brand new classic bug rear view mirror, with nick flip/flop lever for glare. Unfortunately LHD. may suit your needs. $10
Items missing are sold or on ebay. Items on ebay mostly start at 99c, this includes baja kit, vw disc brake spindles/arms, barwork, 1300 long block, beetle rear drum assemblies, altezza tail lights. See ebay for these items.
bajachris88 路
