68 ball joint boots
https://forums.aussieveedubbers.com/threads/103638/68-ball-joint-boots
rebel ·
Anyone know where to buy new ball joint boots ,as two of mine have a tear in them
rebel ·
Looked up an old post ,apparently repco have them
How do I know which ones I need
how do I find the size I need .
any help appreciated
If the boots are torn you should really check the joints with a bar to see if any movement
more than likely they will be beggared if the rubber is torn or cracked
you need the car on a hoist and apply pressure to upper n lower tailing arms to check for movement
vwo60 ·
Try bursons as they have the roadsafe range in stock and these are good quality.
