I am fitting a late modle box to a 68 pan (type 1).
Is it better to use
1) the nose cone off say a 62 gearbox
2) or the later modle nose cone and a urethane addapter mount.
Newt
keep with later stuff there are no changes required
Newt ·
So use the earlier nose (on the later box) as it is compatible with the pan?
Ta
Newt
vduboy ·
I bought a adapter from aircooled.net to go from my 3 bolt trans nosecone, (which is supposed to be stronger) to my 2 bolt chassis, was silly cheap too. Its also not the nasty urethane that can vibrate like hell it is a injected rubber type like stock.
Newt ·
VW54
The pan has the older two bolt mount.
The nose has the newer 3 bolt mount.
So I either stay with the newer nose and an addapter, or use the older style nose off an earlier box.
VDuboy
Are you happy with the addapter?
Newt
vduboy ·
Haven't fitted it yet mate! It's going on my Manxter project, but it look like a quality bit of kit, it actually looks like they have used an original mount and molded on the correct ends.
