Clearing out the shed and need to get rid of a few things.
The flywheel is stock and has been machined. Despite the surface rust I think it should be pretty right to put straight into a car. $20
The roof rack is really solid and would look great on a rat-look. It probably needs a spray if you want that clean look. It is solid steel rather than tube. It is designed to be attached with bolts from the two holes on either side.
I never actually mounted it on my car and don't have the bolts necessary to do so, but it shouldn't be hard to find something to do the job or to fabricate something yourself. $50
As I said I just want them out of the shed so tell me if you think I'm dreaming!
I'm in Ashfield, Sydney. 2131
Ph. 0431624164
Cheers, Ben
bcrossman ·
