SOLD - Type 3 1970Squareback Project
https://forums.aussieveedubbers.com/threads/103733/sold-type-3-1970squareback-project
HotRodMatt ·
1970 Squareback project
Project car. Unregistered. VIN: 3602225357
Body exterior stripped to bare metal, acid washed and etch primed. Inner rear wheel wells bitumen coated.
Good rear guards.
2x good sets of front guards.
Everything that came off it is there (except bumpers - when i bought it it was sandwiched between two other card and bumpers bent) including rear pop out windows/hardware. A few new bits and pieces. Plenty of spares, dizzies, lights, guages maybe even some carbs etc.
Best unrestored Type 3 pan I've ever seen.
There's a few small bits of panelbeating to go - probably just filler work.
Good honest solid body. I couldn't find anything other than surface rust when I stripped it.
Original red low back seats, reasonable condition. Grey upholstered dash and matching grey and white door trims.
Tailgate not painted since stripped so has a coat of "patina" over it. Holes for the taillight "beak" and badge welded for a smooth finish.
69mm counter weighted crank. Standard bearing size - may clean up and remain standard or go to first cut if you wish.
Engine in the car is original. Ran rough before the wiring was disconnected. I did take it for a drive before stripping it down. Shifted but gearstick was loose. Maybe just coupling but I'll say state of gearbox unknown but probably ok.
SOLD
Matthew
Car is at St Marys, NSW 2760
HotRodMatt ·
more
HotRodMatt ·
more
HotRodMatt ·
more
HotRodMatt ·
more
HotRodMatt ·
last pics
