Hi All
I have a problem with my CrMo 200mm flywheel chewing out the main seals. I had the face of the Flywheel machined so I could get 3 shims in for 0.004" end play. When I put a seal in flush with the case it chews out straight away. I put a new seal in as far as it would go and you can see where the edge up from the lip of the seal was rubbing on the flywheel. Question is what do you try next? I have thought of getting the back of the flywheel machined. Any other suggestions?
BTW flywheel is an Empi 200mm, lightened and CrMo..........
baja_01 ·
