A long, long time ago, in a machine shop far, far away (I remember seeing that in the cinema......Jeez I'm old! HAHA!), people didn't have access to 4140 and 4340 cranks from the CBs and Aircooled.net's of the world, because there were none.
Instead, they offset ground their cranks using Holden Starfire rods to get 75mm throws, then they even sometimes used the Holden Red 161 pistons in a honed out stock cylinder (3.375" = 85.7mm 馃), along with 2 BX Strommies to give them 1732cc of cheap VW hotrod goodness to keep the Clevo's of the world at bay between the lights.......
Crankshafts, back on the topic at hand.
I thought I'd get my perfectly fine OEM 69mm crank offset ground to 74mm or 75mm, using aftermarket H-beams with chev journals (can you even FIND Blue or Black motor rods any more?) of course. The reason for this is I would have to properly balance the newly-bought 74mm or 76mm crankshaft units anyway. Offset grinds are about $300 (rough guess), new cranks are $400+ before freight locally, and I'm dubious about the quality. I have heard possibly as much as 5% of all "cheap" cranks (eg, not DPR, DeMello or Dave Butler......do you still do this offset stuff Dave?) have index and quality issues also.
Please don't see this as a slight on the Chinese manufacturing ability, rather see it as a slight on the importers who want their products at a price-point not a quality mark.
Since I'm old enough to remember Star Wars when new, and I live under a small rock inside a deep cave on the edge of a desert, I figure a few of you blokes know more about the "new ways" as opposed to the "old ways" like me, and so can tell me if these new 4140 cheaper cranks are good enough to take a punt on for a 5500rpm streeter in an El Bug, or whether I should just say "Aw, f^&k it", and put 88mm thickwalls on a stock crank and just call it too hard to make a baby stroker with excellent balancing unless I spend over $500 for a shiny piece of something from someone.
Not trying to be smart, a few of you blokes out there have done it all, but new and shiny doesn't necessarily mean good.
May the Force be with you.
modnrod 路
