ok i have a 1600tp vacuum advance standard carbie type 1 with a miss fire that gets worse at the bug gets hotter, keep her steady and not so bad but accelerate and away we dont goany ideas, just put in points plugs leads hmmm need help
clyve ·
but now wont idle any ideas its a vacuum advance tp1600
Dirty idle jet. Takes 1 minute to remove and give a blow job to clear. My Mrs does it all the time.
nils ·
Lucky bloke 😀
clyve ·
wish my misses did it
Check for vac leaks
The fact it gets worse makes me think it has something to do with the choke / air fuel ratio
And if that doesn't work - try the blow job 🙂
clyve ·
seems to rev ok but as you accelerate in 4th this is when it gets rough and in the last few days of cold there has been no problem.....
