Painting inside of rear torsion tube
https://forums.aussieveedubbers.com/threads/104141/painting-inside-of-rear-torsion-tube
Newt ·
Hi Guys,
Has anyone found an easy way to paint the inside of the rear torsion tube.
I figured that while it was appart it wouldnt hurt to do this.
Newt
brush on a stick should do the trick
get a plastic brush n bend to 90 deg attach to a stick
I go the rust proof direction as to me paint will only lock in the rust that's already there, even surface rust will continue to gro when the moisture is locked in. And I use rust prevention that does not dry and also seal in the rust/moisture.
Newt ·
Matt
Were you thinking about a POR 15 type process, fish oil, or something else?
Ta
Newt
yep Matts right u have to get ride of the rust n crap in there b 4 u use the 90 deg brush
PM replied to Roger. 🙂
