Just need to know if piston deck height for 1300s is the same as for 1600s. Need to know the deck height for a 1300 and have some 1600 pistons.
Cheers.
pete wood ·
https://forums.aussieveedubbers.com/threads/104162/piston-deck-height-1300-same-as-1600
pete wood ·
modnrod ·
pete wood ·
Thanks.modnrod wrote:If you mean the piston "pin height" measured from the centre of the pin to the top of the piston, then yes, they are the same, and so are the pin diameters.
vlad01 ·
the term is called compression height 😵💫modnrod wrote:If you mean the piston "pin height" measured from the centre of the pin to the top of the piston, then yes, they are the same, and so are the pin diameters.
fish26 ·
