WANTED 1957 Split Case Transmission
https://forums.aussieveedubbers.com/threads/104188/wanted-1957-split-case-transmission
6volt ·
I know this is a long shot but I'm after 1957 Split Case Transmission.
Needs to be stamped between -
A-1114506 and A-1189006
where are you located ?
I have a few, you want complete, working, case, parts???
Can you be more specific
6volt ·
I'm located in Victoria.
I'm happy to organise a courier for pick up.
Most important to me is the case with the correct numbers.
If you have anything pm me with the details.
Thanks!
bnicho ·
There is a split case trans lying loose inside a crumpled Oval at Flynn's Wreckers in Cooma NSW. I don't know what numbers are on it though, and he is not cheap!
6volt ·
i'll keep that in mind. thanks
I have 5 or so, just no time yet to check numbers as they are not easy to get to. I will do it for you some time if you wish, but may take time.
