I have a brand new 1800 cc kombi transmission here that is yet to see oil . This was completely rebuilt using genuine factory replacement parts . This is a stock replacement unit for $ 1230 exchange . If you don't have a good usable core you will need to come up with an extra $ 300 . This box is located in Wollongong NSW and can be shipped @ your expense if necessary via Toll express , ROD , 02-42729920 .
shmicko ·
hi rod excuse my ignorance but can a 1800 gearbox work with a 2ltr engine?
RodPenrose ·
Shmicko , the engines and transmissions are all interchangeable . You have to match up the correct bell housing with the correct clutch . The 2.0 L trans is 8 mm longer that all other Kombi transmissions and therefore you may have to slightly alter your shift rod length . I also have a good supply of genuine syncro rings , bearings , seals and gaskets in stock if you want to get your trans rebuilt by your guy . All of the necessary components will run you about $ 450 - $ 500 to rebuild your trans . I also have a shit load of new and used gear sets , ring and pinion sets etc. , ROD.
silverbullet ·
did this box ever sell i assume by now it has though.
