Aussieveedubbers · Country Buggies
Anti theft/Deterrent systems
https://forums.aussieveedubbers.com/threads/104301/anti-theftdeterrent-systems
steveo169 ·
Hi all
I am interested in what anti-theft systems (deterrent ) you have on your CB's?? Interested in ignition locks, chains, imobilisers, since a club wouldnt work (it would silly if someone drove off with one on and the windscreen down etc
bajachris88 ·
Not CB specific, but i have a tyre lock. As long as they don't have access to a spare tyre, it'll give a thief grief.
The other option, which is an oldschool emmobilizer that my grandfather taught me, is to take to dissy rotor button out and put it in your pocket. Its a pretty quick process to remove and install. No good if you are just ducking into the post office though.
Matt Ryan ·
A generic "I love dogs" style sticker in a prominent position, then place a rubber dog turd on the drivers seat. Works a treat.
Or you could try the beetle style gearshift lock:https://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-798-700
Regards,
Matt.
If you are going to insure with Shannon's you will need an approved system
cb john ·
Nobody asked me anything....I'm with Shannon's...
Paulc1964au ·
i have a fuel pump and fuel solenoid cutoff
58camper ·
I have been with Shannons for 13 years without any questions. ( I guess questions will be asked if happen to make a claim)
As far as a deterrent goes- How about Bluey- a stumpy tailed cattle dog without his muzzle tied to the handbrake lever.
I guess an auto electrician could wire up an immobiliser of some sort to provide a little piece of mind.
I like Paul's idea of the fuel solenoid cutoff
countrybuggybill
HappyDaze ·
My Spyder has a similar problem, being open.
A hidden switch in the [electric] fuel pump circuit, or a fuel shut-off as Paul says may help. Make sure the switch is hidden, but not easy to see you using it.
Mine is hidden under the......hang on, you fool.🙄
You already have an anti theft deterrent, its called a Country Buggy 😂 😉
sander288 ·
what you need is a cougar
grumble ·
Craig Torrens wrote:You already have an anti theft deterrent, its called a Country Buggy 😂 😉
A bloke I used to work with ran a H/T lead to the seat to give anyone using it a thrill.😂
bugmaniaar ·
Yeahh i need a cougar too,wife may not be too happy though😂
58camper ·
How about a gear lever lock from Wolfsburg West
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=ZVW36LATE
Might need to workaround a tad but it gets good reviews on Samba.
Not expensive at US$79
countrybuggybill.
waratah33 ·
Hi vw made a gearbox lock. you put the car in reverse and turn the key best antitheft ever
have one on my beetle i will send a picture of it
