Hi ,
I'm after a beetle steering box.
Preferably in Melbourne
Please reply on here ,via pm or sms
0412370071
Tony
Are you after a standard or super beetle ?
I believe you can buy new standard ones
Tonz Magonz ·
Thanks ..
Non-Superbug type..
Experimenting with running a second box linked to primary one to allow equal length tie rods to be used on a 6" narrowed link pin beam..
Ok. Out of my league but sounds interesting.
Just thinking though
Does it mount where a LHD would mount?
If so, would that mean you need a LHD box?
Special Air Service ·
boxes are the same, LHD & RHD pitman arms.
Tonz Magonz ·
Special Air Service wrote:boxes are the same, LHD & RHD pitman arms.
Correct..
For what I'm doing , either will work..
Cheaper the better as I'm not sure how well it will work..
OZ Towdster ·
Been done before on early offroaders , but not much to gain , why don't you just shorten the drag links
MR930 ·
I ran one years ago on a buggy, in my mind it worked well.
Tonz Magonz ·
OZ Towdster wrote:Been done before on early offroaders , but not much to gain , why don't you just shorten the drag links
The box is positioned to line up with standard Passat steering column ,which puts it further out than normal..
Equal length tie rods will improve steering and reduce bump steer...
HappyDaze ·
PM sent.
Tonz Magonz ·
Thanks Greg..
Nice approach I will consider enhancing ...
Tony
Tonz Magonz ·
Still looking if anyone can help..
Caroneten ·
Have steering box here in QLD could freight to you? Would be $30 plus freight.
