Hi guys & gals, does anyone know the spring rates for long IRS 28 & 30mm torsion bars,also for the std bj beam leaf stack...
Fabo
cnfabo ·
Aussieveedubbers · VW Circuit Racing
https://forums.aussieveedubbers.com/threads/104406/torsion-bar-spring-rates
cnfabo ·
cnfabo ·
cnfabo ·
Well??Craig Torrens wrote:yep
HappyDaze ·
dangerous ·
Just remember the spline section doesn't twist, so that needs to be accounted for to give more accurate calcs 😉dangerous wrote:Wheel rate:
28mm is 242lbs
30mm is 319lbs.
this assumes 26 9/16" length bar and 16" lever.
cnfabo ·
close enough hairy muff....................he heCraig Torrens wrote:Just remember the spline section doesn't twist, so that needs to be accounted for to give more accurate calcs 😉dangerous wrote:Wheel rate:
28mm is 242lbs
30mm is 319lbs.
cnfabo ·
Sides ·
cnfabo ·
Not sure yet dave,give me a month or so to finish the body then I'll decide..Sides wrote:So you goin the 28's or the 30's Chris ?
BRUTUS ·
dangerous ·
Yes,BRUTUS wrote:For a uniform circular rod, the value should be proportional to the fourth power of the ratio of the diameters, so if you know one figure you can calculate any other (for the same material).
